Will i fit 7 x 13 Weller deep dished steels on my mk2 breadvan?
I'm thinking proabably, NO!? considering the squared off reat raches on the hatchback.
Size: 7.0 x 13
Stud Spacing: 4 Stud x 108.00mm (4.25 inches)
2nd Stud Spacing: 4 Stud x 100mm
Back Depth: 100mm
Offset: +3
Centre Hole: 65.0mm
Do you think these will fit with out any scrubbing, (i will occasionally have people/loads in the back).
If no, has anyone got any suggestions of what wheels to put on my 1300 weber carb 87' polo ranger hatchback? i want some girth and want the posibility to drop the car a bit at the back on stiffer springs and drop it a bit more on the front.
  • Views 1k
Maybe if you don't lower it you will get away with it, but it will look totally stupid imo. Stick to 13x6 with a sensible offset if your not keen on modifying the arches.
so you reckon i could get away with stsndard ride height on these wheels at the rear even with a small load in the back?, if so think i would just drop it a bit at the front leave back standard, the way the mk2's seem to stit seems lower at the back anyway, plus the back springs are a LOt stiffer than the front. what other wheels should i consider? superlights?
