VW OEM Solar trickle chargers
Hi,
Has anyone tried those VW Solar Trickle Chargers? They are attached to vehicles when being delivered from the factory to the dealerships to prevent the batteries going flat.
They are available in the usual 12v cigarette lighter plug and OBD & OBD II connections.
I want to get one and was wondering does a 6n have an OBD or OBDII socket?
Thanks,
Mahbs
  • Replies 16
  • Views 2.4k
<OEM whore mode>
I want one. Where do you get them from?
</OEM whore mode>
I think the 6n has an OBDII socket, although it could depend on the year of the car.
Why would it need ODB connection?
The top pic looks like a tricle charger, but the bottom one doesnt
<OEM whore mode>
</OEM whore mode>
You and me both I want one too! (There's one on eBay)
In know the one with the cigarette lighter is universal and can be used in any car, but I prefer the OBD style ones.
Mahbs
ODB was a rapper from the Wu-Tang Clan. :lol:
OBD is the diagnostics port in the fuse box, there is OBD and OBDII.
By pluging into the port it can be used to trickle charge the battery in a similar way to a USB iPod cable, it can interchange data and charge the unit.
Mahbs
Edited by Polo M
Oh ok i didnt know the OBD port could be used to charge the battery directly. sounds cool
slightly off topic but where would i find this ODB port on my '98 6n?
Edited by 89_polo_squareback
drivers side glovebox. open it and it should be on the left. looks a bit like a scart lead socket
is there any reason you couldnt hard wire the chager in the cars wiring? my gt doesnt have a lighter socket so i just hard wire everything!
You could hard wire it in, however, they recommend that you disconnect it when starting the car, I assum on cranking it causes a spike then a surge which may damage the panel.
Perhaps an in line breaker switch could be used to prevent this in your car.
Mahbs
or just wire in a ciggy lighter could be useful in the long run
or wire in a relay so when you turn the key it disables the charger then when the key is removed it activates it. :D
Spot on Ash...talking about relays have you got you remote c/locking to flash the indicators yet?
Mahbs :-p
Mahbs :-p
ummm worse lol haven't even put my white dials in :lol: just been so bloody busy it is my next project then the lights :lol: hows tricks buddy boy?
Mahbs :-p
LOL :lol: I tell you what I'll be at the Polo Show on Sunday if you're there too I'll put your white dials in for you! ;)
Mahbs :-p
:crybaby: I was gonna come as well :angry: but going to a local monthly meet instead :( arrh nuts. I may have a go at fitting em this weekend if I get chance for the meet :lol: knowing my luck I'll break em :p
Mahbs :-p
Come to the Polo Show on Sunday anyway!!! It's only up the road (albeit the road being the M1 LOL!)
