Final polish on my alloys...
well i aint ever polished anything, i bought these polished, but i want to give them a go over to make them really gleem...
what should i use?
thanks!
  • Replies 14
  • Views 1.4k
Autosol?
autosol 110%
some super fine wet and dry 1200 will also be good to clean the surface
as above but wet'n'dry goes alot finer than 1200 grit. I find autosol does a great job but it also may be worthwhile getting yourself some polishing mops.
Autosol if they are a bit dulled, then something like begoum (sp?) metal polish.
Edit: If you have a drill and a polishing mop use that, will bring them up mint very quickly!
I've got autosol and the meguiars metal polish which are both pretty good. Also I just bought a metal polishing kit off ebay and they reccommended belgom (not sure if thats what Kam meant or if they're 2 different products lol).
Out of the two I tried I like the meguiars (mainly because it was cheaper and it was a bigger tub lol) but there isn't too much difference between them.
cool, polishing mop sounds good, anyone got a link to some on ebay?
Just type polishing mop into ebay and it should come up with a load of them.
belgom (not sure if thats what Kam meant or if they're 2 different products lol). << Yes thats the stuff I meant.
If you cant find what you want here you may be mentally retarded...
http://thepolishingshop.co.uk/?gclid=CPueh...CFQ8JEAod5QQx0g
I have the 8pc polishing kit they claim it can do 4 wheels. And there is an added extra for that belgom stuff too.
looks like this...
and i acheived this...
Edited by tomadomeit
If you go on ebay and search for item number 290098956407, thats the one I bought. Send the seller of the product a message telling him what you need the kit for and he'll let you know which ones the best for you, thats what I did :p
cheers jmz, i only asked for a link so i dont go buying wrong stuff, not that I'm retarded
I use peek metal polish and find its better than autosol
yep peek is the stuff 8-)
Regular Autosol in the black tube followed by Autosol super fine in the blue tube :wink:
what are those wheels dan? correct in thinking their VW?
ta
