Fuel leak?!?!?! .......
I have a mk2 coupe s which was empy-ish earlier today so i put £20 in petrol in it. Drove home and noticed that the back to black on my wheels arches had gone grey where fuel had removed it. I thought i must have had some come out as i removed the pump at the station. Later on i went for a drive and when i got out of my car i noticed that petrol was actually visible on the side of my car. It had come from inside the petrol cap!?!?! Opened the petrol flap and there was fuel in there as well so was obviously coming from somewhere around there. Doesn't seem to be any problem with the cap? No rust or any holes in there i dont think?? Anyone got any clues!! ?? Many thanks
  • Replies 8
  • Views 1.6k
there are breathers and a return pipe from the neck the pipes from about 2third of the way up pipe could have perished off one of these
cheers frenchyLX. Is there anyway i can tell this for sure. Not the greatest with my car but i am learning. What would have to be done? Where could i get the bits i need to fix it? How easy is it to fix/find? Sweet looking square by the way. Preston quite close to where i am!!
Way i found it was to jack up the car taking the wheel off and look into the wheel arch, the smell off the damp mud was the give away :D
mine was the return pipe that comes through the inner wing was off.
Cheers i will have a look at that tomorrow when it is light!!
:finger:
Hi mate i had this problem for ages kept checking all the breather pipes and they were fine, turned out the rubber seal o the cap was fooked. I couldnt buy the rubber seal anywhere so i just bought a new cap, was only about 6 quid with the club discount. Now its fine. A good way to check is to block the overflow pipe go for a drive and if theres fuel in there then fuel is getting past the cap which means its failing.
so just block that tiny pipe just in front of where i fill the petrol up? Then go for a drive? Any petrol there then new cap? Sounds good i am work at the moment but i will give it a go on my way home. hope i dont burst ino flames or something like that!! :-) Buy a new cap from where? Mine has a lock on it not that i'm bothered but.....
cheers again
Yeah theres a orangeish pipe that runs down the filler neck, mine was pretty long so i just bent it into a U bend so that petrol would sit in the bend if you know what i mean. If you cant do that try abit of bluetack or somethng. If theres petrol in that pipe afterwards the only place it can be leaking from is through the cap or a hole above the whole rubber caseing. Mine did it mostly when i had about £20 in and some hard cornering.
I got my cap from GSF, and yes its a locking cap.
Yeah the cap prob is to blame then as i have some pretty grim corners on my journey home. I will give it a look when i get home this aftrenoon. cheers for the help!!
