Will these fit .... Offset question ....
Hello all i have some Porsche rims to fit to my car its a Mk4 Polo 1.4 se .
The fronts are 7j wide with the offset ET 55 & Rears are 8j wide with the offset ET 52. 3
Please can you tell me if these will go on with the adapters & how wide will i need the adapters ?
Just that i dont want to go ahead & buy tures & they aint going to fit thats all ..
Any help will be greatfull
Thanks for looking
Matt
  • Replies 8
  • Views 1.4k
if you get adaptors of about 20mm that will bring the offset down to near vw standard. plenty will have done it on here :thumbsup:
Thanks fot that mate !!
Just need to know the offset now I'm sure its about 35
offset of what ?? :?
or did you mean vw recommended offset? thats normally between 35 and 40 on most models
Hi again yeah it was the standard offset i was after on the vw polo 1.4 se..
So its about 35-40 then i take it ..
I've seen some 22mm adapters to adapt the D90 so will these be ok ??
Thanks for the reply
Matt
yea just subtract 22mm off the porsche offsets, so they in the 30's. id invest in coilovers too. much better when fitting wider wheels :thumbsup:
Good man thanks for that will order the tyres & adapters tomorrow & see how i go ...
Matt
All done used the 22mm Adapter kit ....
Looks The dogs will post some pics asap .
4x100 > 5x130 20mm rear and 22mm front this will b pukka fit front and rear :-)
