fitting a gti splitter
hey guys,
dont suppose any one knows how to fit a gti splitter to a 6n
help would be awesome as it would be ready for the polo show :-D :-D
cheers
mike
  • Replies 10
  • Views 1.8k
I used speed clips (z shape thingys) on mine and small screws! Held it proper tight!
you have to cut the plastic clip bits off that would usually hold it to the gti bumper, then either self taper it, or cable tie as i did it on there so it holds nice!
so i am cutting the clips off the splitter, and where about do you screw it in
I'm getting my bootlid tmz aswell wup wup!!!
Edited by mike_6kv
baisically i put some thin cable ties through the metal holes at each end then fastened them up to the bumper, then i got underneath and put a few more here and there! glad you're getting the boot mate really not to sure on what to do with mine at the mo!
used stickaflex to fit mine... (think i spelt that wrong but tube in car so cant check spellin.. lol)
what garages use to fit panels on vans. its lika mastic tube that goes in a gun.. bonded on.
  • 4 months later...
Sorry for the bump...
I've fastened the cable ties at each end but cant find anywhere else to fasten them, care to share some light?
Thanks in advance :thumbsup:
underneath in the middle theres two triangular bits of plastic, i drilled holes in there and then put them through that!
got any pics of it fitted please?
Aha! I got you now mate... thank you!
no problem! cable ties hold my life together tbh
