mk2 polybush kits?
Anyone managed to get a polybush kit for the mk2 at all? If so, where, how much etc..... Cheers guys.
  • 11 months later...
  • Views 1.3k
i got one for 45 quid from gsf be fucked if i can fit it though struggling with some of them not sure on others
You can try Powerflex or Superflex for poly bushes. Superflex are virtually the same thing bar the colour, and cheaper too.
Not the best way,really.
http://www.G-laderseite.de or whatever they're called sell front stabiliser mounts which pull the castor back to the correct position. Standard Poly mounts dont do this and so your front suspension geometry will stay wrong on a lowered car.
G40 track arms are far better than fitting inner poly bushes to new standard arms,so you only need poly stabiliser-track arm mounts.
any bush kit listed for a mk3 or G40 will fit mk2s as well. The only thing to watch out for as Mikey mentioned is that G40s dont have rubber bushes on the inner TCA joints so those ones will be missing from any kit listed as "G40" but they are readily available by Powerflex etc...etc...
