Fitting Rear Speakers
hi,
iv got at 52 reg polo and pretty sure its and mk6 it the one with the round front headlights, anyways...
at the moment the car has speakers in the front doors and by the dash. i am looking to put speakers in the rear doors. iv looked and its clear that the space where rear speakers should go is empty. i was jut wondering if anyone would know...
-How to remover the rear intoir door panel so i could at least have a look?
-If people know weather the rear is conected up and just missing speakers? (very unlikley I'm gessing!)
-The best way to connect up the rear speakers? (where and how to feed the wires and stuff ect..)
-The size of the rear door speakers needed?
-If any other parts are needed?
and any other info!
cheers!
  • Views 1.7k
speakers on 9N polo are 6.5" midbass driver (165mm) and then the tweeter.
I would imagine the standard wiring loom would be in place with speaker connections already there. Take the head unit out and check if there are four sets of speaker cables in the ISO stereo plug (should have 8pins, rectangular thing)
if there is no mounting baffle you can make one from wood with a router and bolt in onto the door frame. or use these http://www.caraudiodirect.co.uk/speaker-adaptors-p-5443.html
http://www.volkswagen.co.uk/accessories/de...o=6Q0051606%20A
cheers thats all great info!!
had a look at the car today and have a good feeling that it is wired up to the back which is great.
was wondering if you or anyone else has any idea how to take of the inner door panel on the rear doors?
(got as far as taking off part of the door handels on the rear and finding two kinda screws. took them out but got stuck, the window winder eamed a big problem and could work anything out!)
any help, adive or info would be much appreciated!
