Info regarding False Floors
As above, Or at least i think that's what their called, Any info would be much appreciated as I'm looking to have a go at it in the next couple of weeks, Also do you just need to make the top and back (The part that goes against the back of the front seats ?) Or do you have to make both sides as well ? Am i making any sence :? ?? lol
GHrab a bit of wood cut it and carpet / paint it .. Pretty simple really .. use the shape of ure boot carpet and the some measurements ... Try and put some foamy stuff underneath and around the edges to stop it from rattling .. I need to finnish building mine ..
Ok cool cool, What about in regards to putting a sub in there ? I mean i no the best place would prob be where the spare wheel is supposed to sit but would i need to make a box for the sub inside the spear wheel space ??
Omz
Omz
I would build a box t o sit it in yes . This will cut vibrations . Its real annoying when you spend hundreds on a decent sub and then it Vibrates . Build a box that is secured around the well and secure the speaker into this and build the false floor around that . Personally i would cover the speaker with something however as i have had some problems with thieves due to having speakers on show and will neve go through that mistake again.
Yer fair point mate, I dont want some pikey tearing up all my hard work just to get their dirty hands on my sounds lol. Cheers for the info mate, Much appreciated,
I think ill be poping down to the salvage yard for some wood Lol.
Omz
Seen people re-inforce the spare wheel well with plenty of fibreglass to strengthen it, attach top piece of wood, make it air tight, cut hole out, insert sub.
Not quite sure how much it rattled tho tbh.
