oil cooler
as above to fit my g40 anyone have anything cheers :-D
even just the plate if anyone has one or knows one that fits.
Edited by lance_gt
  • Views 1k
anyone???
i got a full kit off rallye design for about £120, n that was with a thermo switch plate and stainless hoses.
Use the takeoff plate from any fwd GM. It's got an integral stat and is widely available from scrapyards. Get the fittings and hose from a hydraulics supplier and then you just need a suitable rad.
my mate has a take of plate of a redtop motor so that will do ???
thanks for the info you might just save me a few pounds
They are all the same. Make sure you get the mounting bolt, it screws straight into the Polo block.
check you out ha ha thanks mate ill do just that! :-D :-D :-D
