mk3 clocks ( any )
as above cash waiting 4 a working set of temp/feul gauges and the speedo unit with around 90k
Edited by mrgt
  • Views 980
If it helps widen your search you can swap your speedo unit into the new clocks by undoing the 6 screws on the back of the clocks. This means you dont have to get some GT clocks with the same mileage as your car currently has.
I'm affraid i need a new speedo n e way as mine is bust
How do you manage to get through so many sets of clocks?
well this is a repost as i didnt get hold of the clocks i was guna get in the first place but all the speedo's I've had the needle has been so tight gettin it of they av just broke and the last speedo i dropped on the gloor which explains y that 1 broke
bump
got LHD g40 one
I've got a set with blue lights and red needles if thats any help?
got about 86K on them
