PCD CONVERSION 4X100 TO 5X112 ???????
hi guys,
I'm new here, as you can probz see.... just wondering if any of you lot might know, where i can get adaptors for to change from 4x100 PCD to 5x112...if you know any links or prices or contacts, would be really usefull as iam in a bit of a hurry.
cheers :smoke:
Edited by black_mk2
  • Views 3.1k
www.venommotorsport.com
FK adaptors £65 a pair i think, 25-35mm thickness., come with 8mm allen key bolts to bolt to the hub, the your wheels bolt into the adaptors
thanks mate for that...but on their website http://www.venommotorsport.com/shop/index.html
they only do 4x100 - 5x100 :( or 4x100 - 5x130
any 1, else know of a place????.....
bump.
Well they sell 5x100>5x112 so you might wanna give them a call and ask,just in case.
4x100 -> 5x112 is not possible as a couple of the bolt holes will overlap :thumbsdown:
Sorry bud
Sorry bud
Yep, you'd need 4x100 to 5x100 then 5x100 to 5x112, I imagine the wheels would stick out a lot with that lot behind them!
There was a custom set for sale a while back, might be work checking on E38
