mk3 factory sunroof wind deflector
Hello, I was wondering if anyone had or could keep an eye out in a scrappy for the wind deflector complete with non rusted through arms that goes inside the factory sunroof on a mk3, its a 2 minute job to take off with a screwdriver. I also need the seal that goes around the outside but I'm not sure how easy it is to get off, mine is really perished and i could do with another one.
cheers
liz
  • Views 555
think theres one at my local scrappy so will get it if i can when it finally stops rainin!
Is a mk2 golf one the same?
I will look out for some deflector arms for you, golf/scirocco/jetta and i think audi ones are the same. Changing the outer seal is a bit of a pig iirc on the mk3 factory roof panel. You have to completely dismantle it and remove some mastic sealer.
cool thanks, I need the whole thing as mine was totally rusted and i threw it in the bin! lol!. A glove box door would be quite good if you find one of them as well :-)
cheers
