GT engine, gearbox, loom and ECU
I'm after the above, i was planning on fitting the GT running gear to my Mk1 Jetta and i've been having trouble with the carb so now seems the perfect time. I want everything needed to run the engine and would prefer standard spec + no leaky headgaskets but will consider anything for the right price. What have you folks got?
Edited by Retro_Tony
  • Views 481
In-tank lift pump an inline pump also wanted.
