button not working on new wheel
hi guys just fitted my new omp streeing wheel and the momo boss kit only has one wire for the horn please help
cheers alex
  • Views 1k
The two contacts of the switch will go to the one wire you have and (probably) a metal part on the back of the wheel which will connect to the steering column when the wheel is attached. So you need to make sure whatever the steering wheel contacts to is grounded, and then connect the one wire on the wheel to one of the existing contacts - whichever goes to the horn.
Hope this makes sense! Basically the missing wire is the back of the wheel, which needs to always be grounded.
Ray
sort of soi got to get a bit of wire and connet it to the wheel boss so it completes the circuit sort of things
alex
Yes, I don't know about your wheel specifically but I think that's where your extra connection will be!
will it a omp supersprint wheel with horn button on to a momo boss kit and the horn on the back of it has two conneting bits but the boss kit only have one wire
so il try and wire the second connective bit to the boss
cheers alex
