rear wheel cylinder
easy to fix? :-( sisters boyfriend saw a puddle next to my rear wheel and he said that the wheel cylinder has gone, they easy to do for someone who doesnt know anything about cars?
  • Replies 13
  • Views 1.2k
If you have a haynes and photograph the brakes as you dismantle them then i'd reccomend it. It ain't hard - it was one of the first jobs I ever did* :-D
EDIT: *Which would suggest that even a monkey with no arms could manage it!!
Edited by Chuck Yoghurt
no manual, but hopefully the guidance of my sisters boyfriend (knows stuff about cars)
Ah well then you'll be fine! Get stuck in, man!! :-D (Give you a nice sense of accomplishment - and a car that stops - AND save you money!)
EDIT: PLUS he'll get credit with your sister!!
easy to do, you dont need to remove the brake shoes themselves to fit a cylinder, just the drum
be careful not to round out the 5mm allen bolts, they tend to be rusty
Very true - if the drum is stuck on the shoes you have to stick a screwdriver through one of the boltholes and flick a little wedge thing near the top-right (IIRC). That makes the shoes drop away from the drum.
ah ha, it does indeed, you need to put the screwdriver through with a bolt hole at about the 10 o clock position ;)
cool, lost this topic for a second, thought i put it in the polo chat. but nice one guys, will order the parts tomorrow. and hope they come asap. I'm fitting new shoes aswell. whilst I'm there, might aswell do it.
cheers again
and dont try to undo the brake line from the cylinder without a flare nut spanner (11mm).
What's one of them? :shock:
A spanner that is designed for using on brake pipes (well, most forms of flare-end nuts) so that it doesn't round off the nut. The opening in the spanner is just enough to get the pipe through, and it grips on as much of the nut as possible.
Invaluable tool.
Invaluable tool.
Thanking you ;)
got the parts sitting next to me :) aswell as a manual. had a quick read of it. but I'm going to wait for my sisters boyfriend so i dont mess anything up.
but i think that this is going to be one of many parts I'm going to order.
thanks all
fixed now :) and better than before.
