Rear brake drum cylinders
Just tried to order my brakes (rear cylinder is leaking slighlty and front discs are warped) and they've asked me what type of cylinder it is i need... anyone know??? He asked if it has a power regulator/compensator.... anyone??
It's a mk3 1.05l coupe.
Also anyone know if it's 180 or 200mm drums?
thanks in advance for helping this mechanical moron out :)
Edited by aroncmc22
  • Views 1.7k
You don't need the wheel cylinders for the compensator.
Apparently there are different rear drum cylinders whether i have a power regulator or not... I dont have a clue if my car has one or not..
When i ordered mine i had a choice of 2. It was the cheaper ones, not for the pressure regulator. Since discovered the g40 is the only one with the pressure regulator
there are 2 cylinders standard and G40 ones. there a mm and a bit bigger lol so just fit them there cheep and slightly more pressure can be applied, not that you will notice when driving it. :thumbsup:
You need the ones for 180mm drums without a pressure regulator, only GTs and G40s have the regulators. All mk3 polos have 180mm drums on the back.
Thanks guys, as always very helpful :)
