how to remove a rusty rounded off headlight torx screw
hi id like to know if anyones got any tips on removing a headlight torx screw from a 6n? its rusty and rounded off and i want to remove my lights! I've tried WD40 but didnt help. any ideas?
  • Views 1.7k
cant really say much without seeing pictures but what i was taught by a mate was to drill it out.. not sure on the details but I've seen it done and it works... anyone else familiar with this trick???
How much access is there? could you cut a grove in and use a flat blade screwdriver. other than that, get some cheap torx bits and araldite in the correct one. Might even be able to aradite in a cheap posi drive.
Think big. Weld a half inch extension bar to it and use a buzz gun. That'll undo the little grub.
:lol:
like performing brain surgery with a sledge hammer! :lol:
Youre best of buying a set of torx bits you can fit a socket on to.
Aye they are PROPER shit design like. The fact that if you don't have a thin enough extension bar you have to take the bumper off just shows what a crap design they are. Trox bolts are wank at the best of times.
Think the easiest thing to do will probably drill out the torx bolt then replace it with a normal bolt or a screw. Maybe worth covering the top of it in copper grease so that it doesn't rust over again. Dunno for sure though, worth a try.
