coilover top mount probloms
i have tightened the nut right down on the top of the treaded bit of the coilover then fitted the spring top mount, then the top mount bearing and the bush, my problem is with those fitted the top of the threaded bar doesnt reach threw the top of the turret for me to fit the metal plate and the nut onto the top :?
anybody know what i am doing wrong???
  • Replies 10
use the original spring top seat and the nut that holds the spring seat down (threaded bush).
i have used the original top mount, what goes on first the mount or the nut?
i take it your fitting evo coilovers?
don't use the big blue shiny spring top seat. use the original.
first u put on the spring top seat, then the bearing, then the nut (threaded bush). and the rubber top mount goes on top of all that.
ok thanks mate, that is exactly what i neeed to know, will let uknow how i get on in 20 min
cheers
ok ihavedone as you said but iam unsure on something, i have done what is in this pic but i dont see what is stopping the shaft of thesuspension coming up threw and hitting my bonnet like it did before
can anybody explain
help neded asap people, need the car for work tonight :?
and when i turn the steering should there be any movment at the top of the strut under the bonnet?
ok final question, for the rear coilovers do i use the factory mounts again or the ones supplied with the kit?
this is normal
think i used the ones supplied with the kit
