PhilJ 80mm
hello all. as some of you may know i fitted an 80mm lowering kit from philj and upon doing so the rear sat muck lower than the front. thinking back to fitting it i refitted the standard front bump stops. could this be the reason the car is sitting high at the front?
please people any help would be much appreciated as I'm well chuffed with the rears but the front is letting it down
Dave
  • Views 853
for some reason the rears do sit alot lower all you can do is lift the rear to 60mm iirc?
Yeah, you've set the rears too low. On a mk3 you want them on 2nd to top setting ideally. Let the fronts settle and see what they're like.
