GT dizzy, fuel filter/pump
as above, as i have a juddering GT replacing the parts that could be causing the problem. cheers
  • Replies 9
  • Views 992
bump
bump
bmut
bmtbmtbmt
throttle potentionmeter
buy plugs, leads, dizzy cap and rotor arm new from GSF you skank! :lol:
and change your blue temp sender as well.
That should cure it, alnog with Giogio's suggestion.
ok. but wen you are on GSF, how do you kno what is GT specific?, coz i went on earlier an dint understand it lol help plz
bmt
most stuff isn't GT specific, is there not a GSF near you where you can go in? If it's wring you can always take it back anyway...
