Gearknob and gaitor.
hi guys. can anyone tell me if the gearknob and gaitors from a mk4golf/B5.5 passat fit the 6n polo?
my standard one is all split and nasty.
had a look at the one on my dads passat (b5.5)and it looks identical but i couldnt get chance to remove it and see if it fits my 6n.
anyone know?
Edited by mk4_Aidan
  • Replies 8
  • Views 1.5k
anyone?
I'm almost 100% sure one off a MK4 Golf will fit.
cool. I'm also pretty sure that the shaft diameter is the same.
I'm going to go out and buy one anyway and just see.
intend to:
remove the old gearknob, leaving the shaft behind.
measure the length of the shaft, and the inside length of the mk4 golf gearknob.
cut the shaft as needed ( or as much as possible to give a shorter shift
then hopefuly pop the new one on, tighten it up and slip the gatior over the surround.
anyone want a 'how to' after i have done it?
let us know about this coz I've been thinking about it for a while
i thought about lowering my shaft ( :ninja:) but i found the knob was low enough as is ( :paranoid:) so it would be way to faraway unfortunatly
I just tried downloading that guide andit didnt work but i have it saved on my work pc if anyone else cant download it..
yeh they do fit really simple mod! i used a mk5 polo gearknob in mine but i know the golf ones fit!
