HAS ANY ONE EVER DYED THERE DOOR CARDS
thinking of dying my door cards black I've seen it done before just wondering if anyone has ever done it on here
if so any advice
  • Views 1.4k
Mines plastic so i'm spraying mine :)
There is a stick of it if you seen it in the bodywork section I think? VERY good thread
i was gonna try using sticky back plastic
or fuzzy felt
or possible using a light skim of filler and then painting
i was going to do it, but i couldnt find any in the shops. so I'm jut going to get some spray paint, and spray the carpet material. will let you no how it goes. gonig to do it either monday or tuesday.
Its cheap enougth to just get some black doorcards ...
Are they out of a Genesis or summit .
I had the Manky Fox ones and now i have the black genesis ..
hi it is possible, with vinyl dye.
it also works quite well with normal spray paint.
but if your looking for a better option check out the doorcards that PoloPP are selling.
they are really durable, and weigh 240g in comparison to standard 2kg + each
clicky
Edited by currie
They look spot on .. Nowere to put your stuff though ..
indeedy, i am looking into the fitting of pockets.
