B pillar vinyl for mk2 driver's door
I know this has to be taken off with a heat gun in order not to snap, does anyone have a bit anywhere?
I want the piece that goes next to the window on the driver's door please.
Failing that can someone like DK sell me a bit of the right vinyl to cut to fit?
  • Replies 9
  • Views 1.3k
Haha mine's in bits its well hard to get off without it snapping. Vinyl is probably your best bet really.
vag do em - but Dknight does em too - already sized up etc to fit
pete
yeah i do a set for the mk3 coupe, door bits and the bit on the actual b pillar...
sell the set for £16...
pm me if you want it, mightaswell swap them all!
Dickhead question I know, but are mk2 doors and pillars exactly the same? What's best to stick it on with?
the doors are same yes, but the body pillar, i will have to check
the textured vinyl has its own adhesive on it!
i will check,i have one in the shed that i managed to get off with no traumas.ill let you know over t'weekend
cool as all my others are mint!
If not I'll have a set off you Dan.
reusing an old one is near imposible...
but hey it up to you!
yeah , i think there will be stickyness issues,i.e not sticky enough, i suppose a good contact adhiesive might do the job,but if it dont work,then it will be a waste of time when you could of just got a set of new stickies off dan,and be in stickiness heaven. :-D
