fitting a tachometer
does anyone no were abouts i would fit a tachometer in the engine bay what do i need to connect to what cheers if anyone knos plz leave a message
  • Views 1.3k
I know one of the wires goes to the ignition coil if thats any help...
If i remember right its the middle of the 3 wires that connect onto the dizzy. GT`s have a different dizzy to other mk3 so not sure.
leave the dizzy well alone, the hall sender isnt a suitable feed. on top of the coil there is 2 bolted terminals which you can use to drive a tacho. red one to "15" and black to "0"
i have fitted a pod with volts and a rev counter but i dont know where to fit the 2 wires, could yu please post a piccy of where the 2 terminals are that i can connect the 2 wires to get it to work,
What colour are the 2 wires? if they are for the volt meter then they just go straight on the battery.
The Gt coil isnt a Tube like the Cl isit...
On the Gt theres the high tension lead going to the dizzy then theres 2 bolts...Is tht where you connect it up?
Dan
