10 inch sub
i need to know whether anyone has a 10 inch sub in a box. if anyone does would it be possible for you to post up the dimensions of the box. cause i need to make myself one :?
cheers
kev
  • Views 1.2k
DIMENSIONS: when facing front:Top depth 24cm, bottom depth 37cm, width of box 46cm, height 37cm. Design of box is slanting from top to bottom on back (speaker connector side)
cheers man youve been a big help :thumbsup:
Surely it depends on the sub???
Bolly
Edited by Bolly-Polo
yup, depends entirley on the sub, have a look on the manufacturers website
Yeh, manufacturers site will give the area the box will need to be (usually in cubic feet), so you'll need to work out the dimensions that will give that area.
