1.3 engine and maybe gearbox
Looking for an engine to re-build with quite a lot of trick bits on. Just after the main part of the engine really, don't need either manifold, the carb/injection or any of the other auxiliary bits, just the head and block assembly.
Also after a 5 speed gear box, not the 4+E, but the close ratio one where 5th is the same as the 4 speed's 4th.
I'm based in the south west. Not looking to spend loads, as not much of it's gunna stay original, so just a straight solid head and block, with a good set of pistons would keep me happy, but would like something under the 100k mark.
Cheers, Robin.
Edit: oh, could also do with a radiator and a decent electric fuel pump and regulator.
Edited by RobinJI
  • Views 530
I have an MH 1300cc carb'd unit, v good runner, just removed the head to help me remove from car.
£20 collected, the only thing missing is the carb.
Hey, where abouts are you based? What kinda millage is it on?
Edit: oh, and is that with a gear box or not?
Cheers.
Edited by RobinJI
