stripped out rear end on mk3
was driving back from work 2day in the rain and it sounded like my boot was open i could hear the wet tyre noise wen u go thru a small puddle or a wet road i thought my boot was open or something i dont av n e back seats or n e thing i take it thats y its soooo loud inside the car??? n e 1 else experienced this??
  • Replies 16
  • Views 1.9k
just remove the rear shelf and the road noise goes up , crank up the beat box ,every time i here another rattle thats what i do stereo' on 47 now
Rob
And you're surprised? Back seats make for excellent sound insulation. The parcel shelf is also good,and even the boot carpet helps - though not much,unless you fit something a bit thicker.
You wanna strip the main floor carpet out,then you'll know about it.
Definately makes a big difference. My 205 is deafeningly loud on gravel (as we found at the RR show..), but that's completely empty (only a dash, 2 buckets and a cage!).
mines pretty much the same as that, and is properly loud
sound deaden it
makes a hure difference
I've only got front carpet and seats and it can be noisey ..
Unfortinatly i have no stereo to take away the noise ..
Although i do love the noise my backbox makes when sat puring in traffic ..
You do get used to it to be honest ..
Sound damping would be cool tho . .
why would you do that, you take all the sound dedening out to save weight then put it back in?
This happens to me but i love the noise, echos aswell inside!!!
i wouldnt go and put sound deadening bk in that would defeat the object its onl realy noisy wen the roads are wet really wen ther damp/dry its not loud at all. but if the rear end is stripped right out surely that would encourage the rear end 2 snap out at speed??? they do it alot with the seats in apparently so without ther is surely an even bigger risk??
no. wont really change the handling balance alot i dont think, youve probably only dropped 20kg at most
True, if you remove enough weight from above the rear axle, the car could have a tendency to lose rear end traction more often. I can't say I noticed it, because it's next to no weight, but even in a practically standard car, just junking the rear seats, tookit and spare wheel is enough to feel a noticeable difference in the way the car changes direction.
The answer to this, is fibreglass wings, doors, bonnet and an all-alloy engine, to try and get a 50:50 balance :lol:
Edited by tobyk
Tell you what you notice a enormous diffrence in the amount of front end grip stripping everything out of the back and leaving it all in the front .. Makes it loads more fun to drive .
mine makes a proper r8 noise and you can here every little ratle aswell
mine's sound as a pound !
Try driving a high top LWB transit 300 odd miles with no load, no carpet down in the back, no plyline and no bulkhead. You'll never worry about having the seats down in the polo again.
  • 3 months later...
Would just be far better if the roads in the UK were up to scratch. Roads in NI here are shit, hell theres parts of Ireland where the roads feel like your in part of germany or something, just perfect big wide roads with proper surface.... but never in the UK!!
