Ariel problems H reg Polo
Hi all,
Got a major problem with my g/f’s polo… its H reg and the ariel and its socket that it once sat on has fallen right through the hole in the wing to the bottom… I have purchased a universal rubber ariel to go in there but I haven’t got a clue how to fit it when I cant even get to the bottom of the hole..
Any ideas guys? I see the wings are bolted, do I have to take the wing off to mount the new ariel?
At minute there is just a hole so of course the quicker I get it done the better..
C J Beattie
any help asap would be great :shock:
  • Views 807
Is it a h reg mk3 with the big plastic bumpers? If so then under the front wing is an arch liner. Its held in with several small bolts. You need to remove this to get @ the underside of the aerial. Might need to remove the front wheel or jack that corner up
Hi there
not sure if its mark 3... its square lights and yes big plastic bumbers...
ok mate i will look under arch for liner...
thank you very much for your help :-D
Craig
