loss of brake pressure
i seem to be losing pressure in my brakes. I'm driving along, i brake but my foot goes all the way to the floor with nothing happening, then i bring my foot up, brake again, and its fine. its been doing this on and off for a few weeks now. basically i have to press the pedal to the floor, release it, then brake again to make my brakes work! anyone else experienced this? any suggestions??
  • Views 937
first step is bleed your brakes.if that don't work you have a knackered seal somewhere,check for fluid leaks.
As above.
It's air in the system, or a leak. Check your brake fluid, top up if needed, and bleed them. If it's still doing it then it's likely to be a shagged master cylinder.
More than likely the cylinder in one or both of the drums has shagged, try bleeding first, then take the drums off and inspect the cylinders.
