15s on a mk2?
is it possible i have see loads on 13s and 14s but non ever on 15s because am quite intrested in a set of turbines for my loon or will i have some scrubage problems ?? also any pics of this done would be great
  • Replies 9
  • Views 1.6k
depends on offset, rim width and tyre choice, but it is possible. a 6j wide rim with std'ish offset and 165/50s will go on without any scrubbing. do a search for mk3s on 15s cos the same principles will apply
all this ofset baffels me what do i need to be looking for ?
et38 is std, so best to stay close to that figure. there is a guide on here in the wheels faq page explaining it all!
With a wider than standard rim though, the standard offset could cause fouling on the suspension strut. 6J with 165s should be fine though.
Don't go higher than ET38, I'd say.
i was jsut about to post a topic about this. got a question.
i want g60 steels on my car. 15's, and was wondering if they'd be alright if i went either 70 or 80 low?
cheers
If it's the saloon in your pic, then G60 steels with 165/50 tyres SHOULD be OK down 80mm.
I have 15" 6J Rimms with 165 tyres a 40Ml drop and the wheels still look lost in the arches
Yeah.
Car needs lowering more or a lower offset.
cool, once i get it lowered my friend said he has some 15's g60 steels, so I'm gona put them on and see what they are like, and if they dont rub then i'll purchase some
