porsche 944 seats in a mk3 gt
i have a mk3 polo gt coupe i have just bought some porshe 944 seats without subframes i currently have corberu buckets in. can i use the subframes or do i need to buy some other ones cheers luke.
Edited by polo gt
  • Views 1.6k
i should think youll need new frames, it should be easy enough to weld a frame off seats for your car onto the bottom of those tho
wanna sell your old buckets?
I doubt an off-the-shelf subframe exists to fit a porsche seat into a mk3 polo. You need one of these:
and some of this:
You definatly need a mig welder ..
I have just fitted some Peug seats into mine .
Had to weld the rear of the peugot subframes to the polo
Then i had to cut the front runner off the VW seat and fit to the peaugot seat to align it centrally so it moves backwards and forwards better . Right ballache but so worth it !
Your Porsche seats are flat underside,and will bolt straight to a Sparco subframe with a bit of savvy. Might even be able to bolt them to your current,you'll have to have a look..
cheers for your help guys ill give it a go when they arive and yes i may be up for selling the buckets
