info on porsche wheel adapters
looking for a pair of 15mm 4x100to 5x130 adapters in steel anyone know who sells them told f/k do but nothing listed on there website,,
  • Replies 13
  • Views 1.9k
you wont find 15mm ones mate, the smallest made is 20mm, they're on the venom motorsport website. £70 a pair i think
I run 15mm ones.
Got them from venom motorsport they are indeed made by FK
i stand corrected
whats 5mm between friends???
The amount you chew your tyres in some cases.
i already have the 20mm ones from venom and i have clearance issues , are the 15mm ones steel test ritchie and have you had any problems with them was just a little worried that the studs are not going in many threads especially if alloy,, when did you buy the adapters ritchie
I have been running from March this year and they have been fine.
are the adapters steel or alloy
What ever FK make them in thats what they are. Call Venom and ask
been onto venom and they no longer do the 15mm ones 20mm is the smallest
Call them and ask to speak to Richard
I run 15mm ones.
what size apacers are you running front an rear and what Et are your teledials befor spacers?
at worst you could always buy some 20mm ones and machine them down to 15mm or get a machine shop to do it.
