Arch Fitting!
Yo Guys, MY G40 arches for my MK3 Coupe arrived from Ebay today... Sfter opening the package I have no Idea of how to fit them. Has anyone on here fitted a set and is willing to talk me through it? Or is there anywhere I can find some info on the net?
J10HNY
  • Replies 11
  • Views 1.7k
All i did with mine is get some self tapping screws and screwed the lip at the bottom of the plastic arch and the wing.
Seems to be holding and i also got some apint and painted the holes id just drilled to stop rust.
Cheers mate, found a post which talked about using rivets with the holes under the wheelarch, Does anyone know what size rivet I would need?
not sure what size the rivets are, but don't go drilling any holes whatsover! the only holes you need should be there allready for the arches.
you can still get the little plastic push in plugs to attach them from VW...about 19p each.
No they wont,he'll have to drill them.
As Jack said,you'll want to get something on the holes to prevent the freshly cut metal from rusting. But i suggest rivets,as screws cut into the metal anyway.
I advise you start by giving the arches a proper clean on the inside of the lip where all the dirt gets trapped - always work clean. If there's any rust anywhere,wire-wheel it,dab some Kurust on it,give it an hour,then coat it in your chosen anti-rust paint.
Place the arch into position,and mark where you need to drill the holes with a marker pen (the trims will already have the holes in them for this).
Drill holes the required size for the rivets you're using. There are various sizes to choose from,wide top or with seperate washers,and they're available in black aswell as silver - I've used 3mm slim silver rivets (nice long stems,sure they were over 10mm) with matt black painted galvanised rivet washers on the outside,and natural stainless steel rivet washers on the inside. A couple are always visible from any angle,being silver,and that's a question of taste - though my 185x55x14 tyres pretty much cover the ones on the front.
VW may still stock the wide black rivets they used,but they're likely to be expensive if so.
I like these,though i find them too bulky for arches.
but that's what they came with from factory? I found they sat flush once pressed in, way better than the mk2 ones I have to use a rivet gun for.
I just cleaned the arches and rivited them on through the holes that were there alreaddy .
You shouldnt have to drill . Well i diddnt have to .
i didint have any holes for the arches i had to drill them
mine haven't moved since haha
Cant you just bond them on, silicone or simular.
the arches should be affixed using the correct rivet into the holes provided.
the side skirts to go with them will require a drill and rivets again.
NOTE: be careful with drill as when it hits the panels under the sills the drill will snap
