both windows broken!HELP!!
my drivers side window, wen you open falls straight in.i told vw an they want 70 quid for what it is.is there nefin else i can do
and for my nearside window it goes down fine,doesnt fall in,but wen it goes up it goes slow then stops halfway.i have to pull it can anyone halp what to do.I'm stuck!!!
  • Views 1.5k
plz can ne1 help?
DIY?
Take you are door cards out. And take the motor and brackets out of the doors. Reassemble them....find out what the problem is. Mostly likely the clips to hold the glass is gone thats why it falls through.
I had the same problem a while back, the clips had fallen off. & there was a bolt missing that when my window was smashed the auto glass guy just sealed it together without a bolt but as it was sealer it stretched everytime i put the window down.
Its easy enough to get the door apart. and you'll see the problem straight away.
Besides now its cold what you wanna go openin windowss for :p
I had a similar problem..but mine was to do with the wire used to wind the window up/ down.. but judging by the replies here seems not to be quite the same!
yer i know ones the clips i saw that but i dont understand why one goes down easy enough but doent go up after halfway.they are ellectric if that helps
I aint got electric windows so can't say much more sorry :retard:
sounds like you will need new regulators which are expensive as you've already found out by the sounds of it!you cant buy the clips the break off, which is a shame cos they seem to be the main cause of failure. you can bodge them on with a washer and self tappers though if your skint.
