Heated mirrors
I hate getting into my car on a cold morning and not able to see anything out my mirrors. I'm lazy and don't fancy stretching over to the passenger side to clean the mirror, and anyway when you clean them they just smudge.
So - are there any heated alternatives? Any high spec Mk3s come with them? What about Mk2s, I know some of them were pretty well specced up?
Or Scirocco, Golf, whatever? Any ideas?
Cheers.
  • Replies 11
  • Views 2.3k
its well easy to do mate.
the heated glass works by putting a current through an element in the glass
= a positive and negative connection.
use two wires and attach them to your heated rear window wiring.
the only dificult part about this mod is where to run the wire!
i sheathed mine and run it through with the adjustment cables.
if i remember correctly i used fiesta glass which was glued/bodged onto the original holder.
HOPE THIS HELPS!
Youngprodigys
That's ace, cheers!
Need to pop down the scrappy now...
HOPE THIS HELPS!
Youngprodigys
Hmm interesting.. I had thought about mk2 golf ones but apparently (and not surprisingly!) they don't fit. Do you remember which fiesta it was from? I guess apart from the shape of the glass it doesn't really matter what car you get it from?
I feel for you toby, I'm too lazy to reach over as well :)
cant remember what fiesta - it was very old. its the size of the glass your after!!!
if a mondeo or ruddy maestro glass was the right size it would be ok, aslong as it had the elecy contacts
Great, thanks! I'll make a template of the inside of the wing mirrors and hopefully take it round the scrappy at the weekend, see what I can find!
Is there an easy way to tell if they've got the heater element?
i usually reverse out my drive in the morning with the window open to hear for cars as i can't see out of anything, except windscreeen!
the electrical contacts are a bit of a give away!
+ some cars have a lil image of a heatwave
:-p I meant from the front actually :lol:
Thanks though, at this rate I might have added enough 'luxury' extras to my polo to make it up to a base spec new car lol.
how would you heat a non heated mirror?
run a series of resisters behind the mirror?
Found this DIY mirror heater
If you want to attempt this, make sure you read it all
I found a rocco in a breakers with heated mirrors! Just to let people know...
