Rear washer not working (6n2)
Ok, so rear washer doesn't appear to be working. I'll start by poking a pin into the hole to see if its blocked but if anyone has an experience of them not working and the reason why I'd apprecaite some pointers.
Just looking to see what you guys know so I know where to begin my investigations; ie do the block up at the bottle, unions / joing or at the ball / washer head, is there an in-line filter anywhere, etc etc (stuff like that)
Muchos grassios !!
  • Views 1.4k
how long do you press the button for? mine sometimes take's 15-20 seconds to start squirting.
Ta! Not held it on for that long. I'll give it a try
EDIT: well don't I feel like a complete fooking muppet. I was pressing the wrong button. I assumed that cos the symbol is the button you press in at the end to activate the rear wiper, that you keep it that button pressed in to activate the squoosher - DOH!
Only after I removed the water bottle to check for a blocked pipe at the pump, poked the jet hole a few times and then while looking stumped / puzzled I thought I'd push the whole stalk forward like my Golf and hey-presto it worked fine.
:oops:
Edited by SixDegrees
