mk2 breadvan de-bumpering
how do i remove the bumper? i saw two rivets behind the bumper but no bolts, then i think the bolts are inside the engine by right up front, but not sure, help?
also getting them alloys refurbed and sprayed in any colour for 150, I'm thinkin matt black...good deal? their 6j wide so will i need any archwork incase their too wide?
the cars gtin a 90mm drop next week so need to kknow if the rims fit, and look good?
  • Replies 9
  • Views 1.9k
Aren't those alloys 4x108?
wobble bolts? or is it a no go?
Will wobble bolts accomodate that much change?
not a chance on the wobble bolts. front bumper is bolted on from inside the engine bay, cant remember about the rear.
Wobble bolts can only do about 2mm,as the holes wont line up further than that - if they're 108's,forget it.
The front bumper bolts are in the bay right next to the chassis legs. The rear bumper bolts are in the far corners of the boot - two 13mm bolts for each bumper.
There is a clip on each corner,this is removed by poking the two centre tabs out of each clip from the inside,far enough to be able to withdraw it all in one piece from the panel. They're push-fittings.
cheers. ille find some other pair of sumthing. thnks
if you remove bumpers your car will fail its MOT, one for having no number plate lighting and two for not having easily visable indicators from the front. unless you were planning to rectify these issues.
thats without the police legalities of not having them, one guy on here got stopped for not having a grille!
924s are 4x108?
there is a way around this. you can fit audi brakes (not sure which ones though) up front to give the required 4 x 108 and then get the rear drums re-drilled by a machine shop. it will cost you but its the only way to go if you are desperate to run those wheels. there was a guy on here way back who had fitted audi brakes on the front of his mk2 loon and they certainly improved the braking of the car no end, so its a worthwhile mod anyway!
