i am doing a college project with a gt engine and have £1000 budget?
i have £1000 to work on my GT engine at college so i have all the equipment and a rolling road to test it at the end, whats the top things to do to the engine with the amount of money?
Edited by heartagram
  • Replies 57
  • Views 7.9k
If you do a search its been asked and answered millions of times.
changed the post to come thing different now
What are the aims of your project? I've heard of folk doing projects which are theory but not so much the practical side, interesting.
I mean if its to get as much power well that sounds abit normal but maybe your doing a study into different manifold flow dynamics etc that would be cool.
I'll keep and eye on this thread....
Matt
yer big power, i will start with stripping it down, cleaning it, then gas flow the cylinder head and put in oversized valves, port the inlet manifold, get a 4,2,1 stainless steel decat manifold with a twim dtm back box, a 268 268 cam,
i have heard i can bore the cylinders a small amount and put oversized piston rings in but i am not sure thats advisable.
then get a sports clutch, just get as much out as i can, i posted this to see if any others have different ideas on what to do.
warren
Spend some time working out how to get the maximum airflow into the engine perhaps? I wonder if you can DIY throttle bodies or bike carbs within that budget? £1k worth of engine work should make it a very interesting finished product.
I reckon you could easily DIY bike carbs for under £1k. I'm doing it at the mo (slowly) So far has cost me less than £30 :p
Will be interesting what you do with this project.
also slightly off topic, what course are you doing at college?
hmmm... it's not as easy as that i'm afraid... you can bore the cylinders and put bigger pistons in.
Bigger pistons can be expensive. Tried a homemade Turbo?
cheers for all the help, and for the person who asked i am doing a national diploma in motorsport engineering.
yer so how much power will running throttle bodies cost, and is there a specific bike a get them off or cc?
cheers
Sounds interesting mate..wish my college did the same thing!
Good luck
Wish i had a chance to do something like that too! Now i have to learn as i go along!
warren
doesnt sound like a project, more of a buy bits and bolt them on.
why not look into the flow characteristics of the heads, Dom recons that a 1l head with 1.3 size valves will flow more than a 1.3l head.
how about upping th CR a bit higher than most people would.
rather than just building an off the shelf gt wich will see 100bhp+/- Original?
quick question, is the project about making bhp increase for race use or are you intending on keeping it a road car and modifying for the road?
the reason i'm asking because changing and uprating all what your doin has effects on the emmisions so if they are not considered you have a quick polo gt but no mot to get in on the road, just something to consider...
sounds a wicked poject though, i'm in my 2nd year for a btec nat dip in motorvehicle n guna do a degree next year in motorsport engineering, our project we didnt get much time else me n m mates was guna build a bike engine go-cart but they only gave us 6 weeks including planning an write up :(
I'd say a nos kit has to be done lol, jus aa 20-30 bhp increase though so you don't really need to uprate anything, and you planning on top end power or low because high lift cams will give gd top end power increase but reduce you lower end. another idea, y not get hold of need fit a supercharger?? u have a grand lol, but 2 head gaskets to reduce the compression and a straight through system from a 4-2-1 and port polish and oversized valves, just an idea
gd luck though
oh and if you want it more of a custom project why not create you are own air intake to create turbulance in the air intake? maybe heat an intake hose and spriral it to create a vortex?? better combustion more power... if you think about it you can do alot for notmuch money, just remember the main points, you need a good flow into the cylinders, volumetric efficiency, and a flow out just as good as in, think about fiddling with the valve overlap time to get it perfect... i wish i was doin your project!
Edited by freeman-16v
Why stop at a 268 camshaft? If this is a pure out and out power engine, you want as much air and fuel in that can get burnt, then thrown out the back as quickly and efficiently as possible.... Buy a head - do a lot of research into head dynamics, get it ported to perfection...!
you could always look into other 16v heads and see if you can get any to fit, i'm not sure about the mark 3s but something else to think about. all depends if you see the project as a buy and fit or a fiddle around, custom, creating sort of job
1.4 16v heads fit physically i believe, think you just need another tensioner.
please dont go down the two headgasket route. if you do get any desent power its just going to pop. simple as
I think you will need to clearly define your project goals before you can continue. I did a BTEC in mechanical engineering and did a project on the motorbike I had at the time. I got a distinction for both parts and I'm currently in the 2nd year of a mechanical engineering degree so I am in a good postion to help you if you want any advice. I would strongly advise against just banging on any parts you can think of, you need to think about the flaws in the existing engine design in accordance with your particular goals and methodically think about how you can modify the engine for those goals. For example you must decide whether or not you are going to use forced induction before you start, as a turbo/supercharged engine is going to need a completely different setup than a high performance N/A engine.
Definitely get project aims/objectives first. For instance, are you going for maximum power? torque? reliability? etc. etc.
Is it your money or the college's? Because £1000 is a hell of a lot of money to be throwing at GT engine. It would pretty much guarantee you 130bhp though, which has been achieved before with a similar amount of money.
For this setup iirc-
1. Proper head rebuild- big valve head (e.g. golf gti 8v valves) 3 angle valve seats, gasflowed, ported and polished, port matched inlets and outlets. You can get this done here: Hiflow heads
2. Get hold of an audi throttle body, think its from an audi 80. It's massive and fits with a bit of work. And redesign the induction system, get a golf gti 8v AFM to suit. Consider G40 injectors and an uprated fuel pump.
3. A schrick race cam, think its 268 or 272, will probably run like a bag of nails on idle.
4. Don't get a DTM exhaust- they're shit. Get a custom exhaust made one with a single exit backbox, decatted of course. At least 3.5" and a decent exhaust manifold, G40 or better.
5. Custom map/chip for the ECU
6. Decent service and top parts- plugs, leads etc. Convert to seperate coil & amp packs which you can nick from a golf gti 16v.
7. The obvious stuff- decent gearbox, decent brakes, decent suspension etc.
Why don't you get a G40 engine? Apart from insurance price they're the better option imo. And for this reason I wouldn't recommend putting a turbo on a 3F, there's just no point is there!
130 brake from a GT, for a grand?
OK then...
Yeah, if you have any bargaining power. Not if you go down to demon tweeks like a numpty.
Edited by mr_poloGT
I think it's do-able for a grand!
A 4 branch, decent exhaust, a Schrick cam and some headwork won't leave you change from a grand! And even then, you'll be lucky to be pushing a hundred brake!
edit: that doesn't even including a remap
Edited by tobyk
who said it has to be all new?
Nobody.
But if someone can build me a 130 brake 3F motor for a grand, then do it, and I'll buy it, instead of buying another car.
