i am doing a college project with a gt engine and have £1000 budget?
well if you were to put in new valve seats in you will have a rough edge on the join between the seat and the port. for optimum flow that would need to be smooth. you could also take the opertunity to port the seats and port out to a good shape.
  • Replies 57
  • Views 7.9k
I think getting a good shape would be really important with these heads as they don't have a combustion chamber in the head.
When air moves form a high pressure area (i.e moving fast in the port), to a low pressure area (i.e the cylinder) the speed reduces. Causing in my mind a kind of air traffic jam when the air enters the cylinder. Reducing cylinder filling ability.
My doddgy little sketch is trying to show this.
Also, I think that with a chamber in the head design the space between the chamber and the valve acts as venturi. Accelerating the air again once it's in the cylinder.
Just something else to consider.
i agree but there is a lot you can do to the port to minimize the bad turbulence around the valve. having the enlarged throat before the valve seat helps this alot. its an old book but if you can find it "Theory and practice of cylinder head modification" has all the information you could ever need about porting in it. it is based on kent and A series engines but does cover heads without a cumbustion chamber in them and siamese ports (16v). it also gives you calculations to work out ideal port size in relation to valve size. by using the designs in the book it is possible to have a more posetive effect on flow than putting a cam in. obviously putting a cam in after is only going to improve the results but its worth keeping in mind before jumping at buying a cam if your on a budget.
i paid £100 for my g40 block but that was just the block pistons and crank ect
Edited by Gaz_golf_gti
I looked at that book. It's by Vizzard isn't it?
I might buy it, but I thought it was too specialised on those engines and wanted something more theory based.
I bought Practical Gas Flow by John Dalton, and it's a good read.
I also built my MK2 flow bench.
It's an orifice type bench, but it needs some TLC to get it working properly.
Yes its by vizard. i wouldnt say it was only considering those two engines. he talks more about general port design than exatly what to do on those specific engines. I will have to keep an eye out for the one your on about, can't have enough books. it will be interesting to see if anyone takes these ideas any futher. i was going to downdraught a 1.3 head for my college project but decided against it because i would never use the engine i intended to build.
Edited by D0NK
Yeah, but wouldn't you want to build it just for the sake of building it?
You could always sell it.
Another book I saw today is this.
Not out until next year, but sounds interesting.
The author co-wrote the book I'm reading at the moment.
This is that Practical gas flow book.
Also check out Go fast news for some interesting articles by Vizard.
high rev screamer please. low friction, light weight motor, higher rate valve springs, race cam
search search & search some more for second hand roller barrell throttle bodies that will fit. they is pimp. innit blah
