Update on my Mk4 16v
Has taken me all day but definitely looks better!
what do you think?
  • Replies 22
  • Views 2.4k
Much better!! looks like you done a tidy job of it :thumbsup:
Good job! and nice car! 8-) I'm loving 5 door mrk 4s at the mo!
Ste
nice touch! really like your car!
Smooth as! Nice touch.
Oooh, a silver 5door! :crybaby:
Gti rear disk conversion? did you do that yourself? looks phat! :)
rock on 5 doors! lovin it PIMP
Cheers for all the nice comments!
Yeah, picked up a complete rear beam from a GTI for £85!
Stripped and fitted in a weekend! probably the best bargain I have ever bought for the Polo!
How do you set it up or is non required? ! Brake balance already fine ?:S Sounds goood!
Not much setup required really, The balance can be fine tuned by tightening or slackening the handbrake cable!
Good job :thumbsup: does suit the silver well !
What sizes and offset are your wheels?
8x14 offset 20 with 195/45/14 tires.
Look just right :thumbsup:
Thanks for the comments.
Next things to paint are the door handles and front splitter, think it should look spot on then!
lookin sweet dude
one of my faves this has all the boxes ticked with mods it has had done!
8-)
the handbrake cables adjust the brake bias? ...I'm pretty sure you have got the wrong end of things there mate!
if you have ABS then it'll be ok as long as you have used the sensors otherwise the valve on the rear beam will need adjusting manually
oh and is it just me or is you are car lower in you are avatar?
It has ABS and yeah I did use the sensors that came with the GTI setup.
What I meant about the handbrake is after I fitted the brakes and went out for a test drive I braked hard and the back end stepped right out!
The handbrake cable was too tight and so the rear was braking too much, after slackening the cable it all balanced out and was fine.
As for my avatar 'Photoshop' lol, although I do have some coilovers on order!
have any one got a guide on fitting the new rear beam I've just brought one off a 51 plate gti,
an I've got a 99 16v with abs
Nce and tidy..good job. Mine are going gold :)
