Headunit settings NOT 'saving'
Got a sony headunit and I usually adjust the EQ to get it sounding just right and also I want the clock to show the right time!
It's being a bit fussy but its getting on my tits!
I read in the headunit manual it could be the fuse so I replaced the fuse on the headunit. a little red thing that had a '10' on it. No joy.
Could it be a fuse in the car itself? If so, how can I sort it out?
Thanks very much!
  • Views 1.5k
is your radio saving the stations as well? if it is not it might be your permanent live from the battery (mine does the same thing)
pull out the head unit and switch the yellow and red wires, these are ignition/constant live,
i had to do this with mine, there should be connectors on these wires to allow this, 2 second job,
hope this helps :-)
did it come with an ISO adaptor....i had to buy one, like £5 for a small set of wire and plugs...it basically swaps the signal over which the standard radios use to be able to use a aftermarket unit properly. Which is why it doesnt save, if you do this it should save.
that was what was wrong with mine anyway
swapped the red and yellow wires. connectors already there!
should have come here before I spent £1.50 buying fuses from halfrauds!
Cheers for the help ppls :)
