How to.............
OK, so i've undone and removed all the bolts under the bonnet and the one near the bumper mount. What else do i need to undo for it to come off?
Its gotta be done pretty promptly as i've gotta get rid of the car so someone please help...............
Edited by vwmk3jon
  • Replies 10
  • Views 1.9k
anyone?
the 2 or 3 at the bulkhead
need to take the inner arch out and 1 is above the indicator at the back, the other/s are lower down.
bearing in mind that it is glued in aswell its not an easy removal, use a lever of some sort to prise it off.
else you will bend it pulling it off
cheers buddy.
There's one down at the bottom where it meets the sill. It'll be covered in underseal.
I'm confused, title reads 'How to............., remove passenger side wing - mk3'
so why u all talking about under the bonnet etc???
Side wing???
As in the painted bit on the outside of the car above the wheel :)
I assume to get it off is connects in the bonnet somewhere!!!
*blushes like a little girl*
Sorry guys, for some reason I read that as wing mirror for some strange reason! :oops:
You should've shopped at specsavers!
I'll get the screwdriver out in abit if it stops raining for 5 mins to see if i can find the lower ones inside the wheel arch.
I use a flathead and tap all the way along the bit at the top to part the sealant there, heat gun is helpful if you got one.
don't matter anymore. Sold the shell complete......................
