wing vent the DIY way!
So i'm thinking of having a wing vent but as i don't have a welder and would probably make a mess if i did, thought about getting a wing and using a angle grinder to make the necessary slits. Anyone done it like this before? Anything i've got to think about before/whilst i do it?
  • Views 1.3k
Think about naked ladies :drool:
i do that too much already! Internet porn ftw! lol.
Seriously tho...............................
i would measure twice cut once and then i would go out and buy a dremel as a grinder is a fairly clumsy tool that can make a mess preety quick besta' luck with it
I defineately use a dremmel type tool over an angle grinder for the task!
and you might want to make a wooden mould to go behind the vents so that once cut you can hammer or somehow push the edges in. you're going to need to respray the area afterwards so I hope you've got a nice easy colour to match with.
I'd say it was a lot of hassle if you're not going to be getting a lot of work done at the same time...
Good luck with it though. Take lots of pictures and put up a little guide thing - even if it's just for interest! :)
Matching satin black is pretty easy lol
Jon just get a vent welded in it shouldn't cost you much to get done, then smooth/paint it afterwards yourself.
may just do that mate.
finding it enough fun removing a wing from my scrapper to keep for yeti. Its going to a new home later (good f'in riddance i say - not theres much wrong with it!)
If i get round to being brave enough, i'll make a journal of it for everyone else to look*/learn*/laugh* at
(* delete where appropriate)
