HELP ... 9N Headlights stopped working URGENT!!
Checked the fuse box (which I can never seem to make any sense of compared to the little card you get inside BTW) & all fuses seem to be fine!
Full beam, sidelights and fogs all work, but both the headlights have gone! What else can it be other than the fuse & is it something I can look at & fix easily myself? I'm kinda guessing that both the bulbs wont have just blown at the same time so I'm stumped...
Thanks in advance
Edited by TimGti
  • Views 963
definately sounds like a fuse, check relays too. Also check the wiring in the engine bay. Use the card in the fuse box to help you locate the duff fuse.
Pulled out all the larger fuses and they all seem fine!
Where are the relays mate?, my dad suggested looking at this, would be a great help if I knew where I was looking!?
