4x100 - 5x130 need some adapotrs
as above I've just brought some teledials from ebay .
thanks
sam
Edited by dunces6
  • Replies 11
  • Views 1.7k
stormdevelopments.co.uk do them in 20 - 25 - 30 & 35mm hope that helps!
couldnt find them on the site any iders how much they are ?
just looked at that link an thought wow there cheap but for only 2 ah well..
they say the do the job but not sure what thickness you need someone else should be able to help tho
speak to alexalloybrokers on edition38, he can make you whatever spacers, spigots, adaptors you need fully custom to your own specs...
drop him a pm as he'll give you advise on what youll need to run ie size of adaptors etc
Edited by grungeisdead
Why do you need them so thin? Porsche have deep offset,its not usually a problem.
because i dont want stretched tyres. so if i can buy some thin adpotors i dont need my arches rolled.
any luck with the 15mm adapters was thinking of getting a set made as my 20mm ones are too wide and rear wheels catch arches , just worried theres not enough threads in adapter to make them safe, let me know if you get it sorted
