brake upgrade on a 6n
a 6n with 14s on, will 6n2 gti brakes bolt straight on?
or what other options do i have?
  • Replies 8
  • Views 1.4k
i dont no if the gti are any better but i just got some brembo max disc and some ebc green stuff pads form gsf .
gettin a gti ream beam the to get rid of the brums
GTI brakes aren't any better apart from if you're doing the rear disc conversion! as for fronts and if you're running 14's i'd go for some drilled/grooved discs (got mine from GSF) then some better pads that helped me when i changed! the other options you have is spending big bucks and getting some 4pots!
What's the max size brakes you can run wiht 14's?
256mm.
Out of intrest, where could you get 4pots from?
Chris
how easy would it be to fit rear disc of a seat ibiza gti ?? what would i need from the donor car ??
Is 256mm the biggest for 14's only, or could you go bigger if you were running bigger wheels, advisable/not?
Bigger wheels menas you cna have bigger brakes. Not necassary if your car doesnt go fast thought
