More windscreen wiper problems
Evening all!
it was about time i replaced my windscreen wipers so i thought i will get bosh ones, front ones fitter straight away cliped straight on, yet the back one dosnt, and all the adapters dont make a dif either, any help?
  • Views 1.2k
Try using it without any adapors, I'm very sure they arm connects to the bar of the wiper blade that the adaptors fit around, so, as it were, the arms have built-in adaptors. try that.
i thought of that, so i took the adapters off and the metal bit (like a hinge) is too big and i dont want to push it too hard that it breaks me wiper arm
Hmm, I'm not suggesting that you're wrong, or that you go get a big hammer, but mine were very odd, it felt like it hadn't gone in and was too big but then when i tried to get it off it was actually correctly fitted. Maybe mine is just an odd polo.
or mine is!!
the two thin metal parts that go one each down the side that hold the little metal things dont even sit right on the arm, one sits one side and the other side and they dont sit they right
