late spec NZ push fit water pipe
as title,
the water pipe on the back of the block that is a push fit into the back of the waterpump housing.
  • Views 651
why nz - arent nz pipes same as a late spec gt or g40?
are these just the same as a mk3 spi but with a plate on for the isv?
Yep, a late spec MPI water pipe will do.
or late spec normal pipe and weld/bond a threaded bit of metal on the pipe - dom made me a bit like this if you want one... i dont need it
pete
pete
The late spec SPI ones i've seen are plastic though!
think i have one , its a push fit with the little metal bracket for the valve thingy.
sound right?
