polo gt turned 178 k today now with damage pics
then on the way home from work snapped the cam belt
don't sound good heard a lot of valve piston contact before i dipped the clutch , head off on saturday to check the damage
only taxed it for 12 mts on line on sunday
no rest for the wicked
corrado's now my new daily driver
Rob
Edited by carpy25
  • Replies 12
  • Views 1.2k
bit of a bitch, but replacement head, a mornings work and it should be fine. doubt ther will be any other damage.
Bugger! Mines ticking onto 172k, should really do my cam belt cause christ knows when it was changed last!
same here but mines a baby @ 103k!
got the car at 150k had the belt changed just before 2-3 k at most so theres only 30k on the belt , don't look worn just broken
Rob
Odd? Maybe the water pump seized up and snapped the belt. This seems the common reason to have these changed. I've enquired about this before, and very few people (read none) have ever had a snapped belt through a seized water pump, although the rumor must come from somewhere.
Let us know how you get on and what snapped the belt prematurely (if you ever find out, that is).
possible water pump seized , or maybe snapped cam but either of those usually strip the teeth before the belt snaps ,my belt looked good bar from the break, will be changing the water pump when i repair it
Rob
well the polo is no more started selling bits off already ra's and gt2 front seats gone taking the bling off and selling as a rolling shell has 11 mths plus mot will be sold on alloys close the standard spec
droped a valve holed the piston no bore damage but at least another 5 valves
time to move on me thinks
Rob
omg! how shite is that! my regards to your GT.... RIP
cant believe the amount of damage!
That'd take me a days work and less than a hundred quid to fix that. No wonder GT's are getting rare,when people write them off for a snapped belt.
Well mine is on its fourth belt in 35k miles. Well,you can never be too careful..
it's going cleap as a rolling shell :-D
Rob
thats finished :shock: :shock:
Such a shame to loose a car over that. Shame you can't fix it. But time to go bigger and better.
